15A ESC And 600 Motor Question
Hi all
Is it possable to run a 550/600 motor on a 15A speed controller on 7.2V or 9.6V if so what prop would you use?
Thanks again
Jonjoe
Thanks again
Jonjoe
Hi Jonjoe,
Depending on the ESC (car, boat type?) and the boat, it is possible, but only with a small prop, I'd guess 30mm max, but that really is a matter of trial and error.
A 600 motor can draw as much as 20+ A when turning a 37,5K in a surface drive set-up, getting out of the hole, personally I would't go smaller than a 30A ESC for a 600 motor and that's in a planing hull, kept on the plane for the duration of the run (race).
If you plan to start and stop a lot, 30A might be too small an ESC...
What boat is the motor ESC combo intended for?
Regards, Jan.
Regards, Jan.
Hi there
Its a Msonic marine VIPER 15A its intended for a 24" by 7", semi scale model boat of typical Air Sea Rescue Launch as used in WW2
Thanks again
Jonjoe
Thanks again
Jonjoe
Hmmm, might be on the edge...
Try the combo in that hull, if it draws too much currrent and shuts down thermically, go for a bigger ESC.
Regards, Jan.
Regards, Jan.
