HELP HELP WITH BATTERY CHARGER! :) LOL
Hi all
Can someone help me would this charger thats on ebay be able to charge Ni-Cd's Ni-MH also would it be able to charge 7.2V and 9.6V:
Here is the discription: PICTURE AT THE BOTTOM
Welcome to my auction for a
Archer fast charger for 7.2v nickel cadmium racing packs
Never been used or even taken out the box
input voltage 12 volts
5 amp charging current
minimum supply voltage 11v
maximum output voltage 10.2
minimum charge time 3 minutes
average charge time (fully discharged pack) 20 minutes -/+ 10%
one push start button
charging indicator
reverse polarity input protection
designed for 7.2 volt 1200 mah battery packs 6-cell
no reserve 99p start
please check my other items
happy bidding
ANY HELP WILL BE MUCH APPRECIATED!
Thanks again
Jonjoe
charging indicator
happy bidding
Thanks again
Jonjoe
Hi Jonjoe,
The texts says it all; 7,2V NiCad 1200mAh packs only.
6 cell NiMH might be possible, but you'd have to know the peaking setting, usually, the NiCad setting will tend to overheat NiMH.
The 12V input is too low to charge 8 cell packs (9,6V)
Generally speaking it's an outdated charger.
Regards, Jan.
Regards, Jan.
I would bet that it would not charge 9.6V packs. Also 12V in is not too low to charge 9.6V batts for a decent charger. My $99 swallow will charge 3 cell li-po's (11.1V) off a 12V input. My recommendation is to save up a bit more and get a decent digital charger. They are well worth the money. I recommend the swallow.
Hi all
Thanks for all your help ive now got a inteligent digital charger for 6v-7.2v-8.4v-9.6v and 12v and a charge rate of 600mh or 1a or 2a this is exactley what i needed
Thanks again
Jonjoe
Thanks again
Jonjoe
