My lovely new battery discharger
This is my beautiful battery discharger !
O.k so it is not beautiful but it does the job. I got the wiring diagram off the net and with a few bits I had in my project bins I set to it. Actually I began at 5.30am as I had run out of sleep and my wife was not………..never mind
It takes about 30-40mins to drop the battery to recharge level and then automatically shuts off. The lights are great as I can leave it on the bench in my workshop and see it from the house. When each pack is “flat" ( down to .9v/cell ) I roll a fag and shoot out to swap it for another pack. Over the space of an evening I can discharge and recharge my packs ready for another trip to the pond to run a couple of boats. O.k so now I have 3 boats we shall make that run a few boats.
RE: My lovely new battery discharger
ORIGINAL: rc-freak15
looks nice. where did you get the wiring diagram? how do you make it cutoff?
If you understand basic electronics and can solder then this can be knocked up in an hour or 2.
The basis is using a relay ( 6v for 5-7cell pack ) between the battery pack and the discharge lamps. The coil in this relay releases at 4v. That is too low for a 6 cell pack so we put a series of diodes into the positive line from battery to the relay to produce the lower coil voltage.
My one drops out at 5.15v.
I might shoot down to the station today and grab some files.
