Go Back  RCU Forums > RC Boats > RC Boats General Discussion
Reload this Page >
GelCoat, where to buy it?
RC Boats General Discussion Discuss general rc boating topics here.
Old 06-12-2007, 12:12 PM
JIngalls007
Default GelCoat, where to buy it?
Does anyone know where to pick up some GelCoat? Does anyone have experieince w/GelCoat and how to apply it?
thx
Old 06-13-2007, 10:21 PM
Flabum
Default RE: GelCoat, where to buy it?
you can mail order it from any marine store online like West Marine or look for it at any of the local marine stores in your area.
Applying it depends on what you are applying it to. If it is a repair on your boat, simply get all your shaping done as perfect as possible, and final sand the area with 600 grit. application should be sprayed on for best results. the cheapest wat to spray it is with a sprayer like this: http://www.westmarine.com/webapp/wcs...01/117/11203/4 . You will need Gelcoat, acetone and MEK (hardener). Mix the gelcoat with 30% acetone, then add the MEK by volume of the gelcoat not the gelcoat-acetone volume. Put it in the sprayer and spray a good heavy coat, but not too much to make it run heavily (small amount of run is ok). Spraying it with this type of sprayer will leave it with an orange peel surface. Wet sand the repair with 1000 - 1200 grit and buff afterward with a good gel coat rubbing compound, then wax.
Old 06-14-2007, 08:42 PM
capn gary
Don't get too carried away with the MEK...especially during the summer. It gets REAAAALLLLLY Hot!
gary
Old 06-14-2007, 09:31 PM
Flabum
Oh, but I love the aroma of overcooked gelcoat as it melts the mixing pot
Old 06-16-2007, 06:34 PM
capn gary
chuckle....
gary
Old 07-29-2020, 03:39 AM
RCFlyerDan
My Feedback: (53)
RCFlyerDan's Avatar
thx
Ive been buying my fiberglass needs for the past fifteen years from Fiberglass Coatings. Great store!
https://www.fgci.com/products
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
