Go Back  RCU Forums > RC Boats > RC Boats General Discussion
Reload this Page >
Scratch bulit boat deck
RC Boats General Discussion Discuss general rc boating topics here.
Old 10-08-2007, 07:05 AM
cowana
Default Scratch bulit boat deck
How to I make a deck for my boat? I have made a fibreglas hull, but don't know how to attach a deck. It is for a 80cm 1/20 scale RNLI offshore lifeboat.
I will make the deck from plywood or 1.5mm plastic.
Andrew
Old 10-08-2007, 07:30 AM
rye
My Feedback: (10)
Default RE: Scratch bulit boat deck
hi
what i did was got a 1/8 ply wood turn the boat up side down trace's the boat on it cut on the out side of the line and then sanded to fit and then expony it to the boat ,hope this helps rye
Old 10-08-2007, 08:52 AM
Bauer66
Bauer66's Avatar
Plexi Glass makes great decks. Lets say your using 1/8 inch plex for your deck. Glue in deck edges 1/8 down from where you want your deck to be, If its a flush deck then 1/8 from the top. Run them full length and add deck supports. Cut your deck and fit. I fill my seams with Bondo. Bomdo is a polyester resin and adheres to fiberglass real well. Below are a few examples from my Gearing class DD.
ID:	778680   Click image for larger version
ID:	778681   Click image for larger version
ID:	778682   Click image for larger version
Old 10-08-2007, 11:01 AM
Umi_Ryuzuki
Umi_Ryuzuki's Avatar
Skipper AM299
The Gearing looks great! What scale is it?
[8D]
_____________________________________________
What ever happened to Keith Sargent?
Old 10-08-2007, 11:03 AM
Bauer66
Bauer66's Avatar
Hey Thanks, Its in 1/4" or 1/48 Scale.
Old 10-08-2007, 11:05 AM
cowana
Loely boat!
Does the anchor grip the lake bed? If so, what material is it? Gravel? Mud?
cowana
Old 10-08-2007, 11:08 AM
cowana
If I use plastic/plex, what is the thinnest you would reccomend?
Also, how do you stick to it? (e.g. bollards, cleats, fairleads etc)
cowana
Old 10-08-2007, 11:09 AM
Bauer66
Bauer66's Avatar
Its amazing how well it really works, Even in a slight breeze. As for the lake bed its all the above, Gravel, Mud, Duck Doo Doo and im sure many other things LOL. I got the anchor from Modelshipway They have really nice Anchors.
Old 10-08-2007, 11:13 AM
Bauer66
Bauer66's Avatar
Depending on the Size of your model, I would use either 1/16 or 1/8 Plex. Lightly sand it SOS or wet sand with 400 and then your ready for Paint and Glue, I use CA and that seems to work the best.
