.21 CMB LS trouble
.21 CMB LS trouble
hi it is just what it says
i have a .21 CMB EVO LS in a .21 microburst with the CMB .21 Quiet pipe and am running a Octura X440/3 Bladeprop
it just wont run right it is either too rich or too lean too picky!!!!
any suggesstions would be helpful
.21 CMB LS trouble
Everything else sounds about right. Are you running good fuel in it? Old fuel will make them run like crap. How's your pipe length? It should be in the neighborhood of 3-1/2" measuring straight back from the center of the plug and across to the weld or widest part of the pipe. On some pipes you can measure at the wrong place, I found that out with my Irwin quiet pipe.
.21 CMB LS trouble
No problem. It'd kind of hard to know what's going on over the Internet. Sometimes we need all of the info possible to help determine what's going on. Sometimes I ask too much possibly making people insulted but it's difficult not knowing what a person does or doesn't know. This was not pointed at you, I am sometimes the same way. BTW, what helped?
