Go Back  RCU Forums > RC Boats > RC Boats General Discussion
Reload this Page >
Folding Boat Stand - easy to build
RC Boats General Discussion Discuss general rc boating topics here.
Old 06-26-2008, 12:49 PM
cracker39
cracker39's Avatar
Default Folding Boat Stand - easy to build
While waiting for my Nirvanna sailboat to arrive, I created a work stand for it that folds flat for travel. All except for the cutouts for the hull and I needed the boat to m ake a template for the cutouts. This stand would work for any type of boat, sail or power. If you've been to this post before, you will see a new stand made with nicer B/C plywood.
I made from a single quarter sheet of 3/8" B/C plywood which you can buy if you don't need a full sheet for other projects. The other lumber you'll need is about 10' of 1x4 or 6' of 1x8 spruce or clear pine and some hinges, so it's not expensive at al to buildl. Click on the link below to get the construction plans. You'll have to create your own templates for the cutouts where the hull fits into the ends. Just cut them a little oversize so you can glue in some foam to protect the hull paint.
The shelf below is hinged in the middle and to the ends of the stand. That's what allows the stand to fold up. I made the shelf with a cutout in the middle and placed it high enough so that the keel would stick thgough the hole to keep the boat from tipping over in a wind. I don't think normal winds will cause the stand to tip over.
Click here and select Save To PC to download the plans. http://web.tampabay.rr.com/wdsummers/boatplans.html
UPDATE - 6/27/08.
ID:	978918   Click image for larger version
ID:	978919   Click image for larger version
ID:	978920   Click image for larger version
ID:	978921   Click image for larger version
Old 06-26-2008, 02:13 PM
PondProwler
Default RE: Folding Boat Stand - easy to build
Nice work on the stand. I sent you a PM per your request.
Jim M
Old 06-27-2008, 05:05 AM
fuelman8
fuelman8's Avatar
Got the plans
I'll let you know monday how it turned out.
The plans were detailed good enough[8D]
Old 06-27-2008, 08:37 PM
cracker39
cracker39's Avatar
I finished the new plans for the boat stand, but haven't finished the new stand yet, but should get'r done tomorrow to post pics. The new plans are now on the web site page http://web.tampabay.rr.com/wdsummers/boatplans.html
