Carb 101 with flowchart...carb mysteries cleared up.
It was suggested that I read the instructional document Carb 101 (from cajunairboats.com) and I did. It helped to clear up the mystery of how to get the carb on a glow engine adjusted properly. However, trying to read all that text while adjusting the carb was taxing my brain. As I used to write computer programs, I follow diagrams or flow charts much better. So, I created a flowchart that can be followed easily while working on the carb. The flowchart isn’t meant to replace the text of Carb 101. They should be used together, the text explanations to understand the principles involved, and then the flowchart can be used to do the actual adjusting of the carb. You can access my document at this link on my web site. Or, just right click on the link below and save the document to your pc (save target as) carb101.pdf.
http://web.tampabay.rr.com/wdsummers/carb101.pdf
