brass fittings
where you get the brass water fittings for those water jackets.i made a water jacket for a hextronik 120 amp esc,but need the fittings to connect the water lines.those in the picture is not good.any size would work,i will adjust the holes.
MN
An FYI:
I've read a number of times that people don't want to respond when you improperly post a pic and they have to scroll across just to see what you are talking about. Here's a link on how to post a picture properly and you may get some help.
Also "hextronik 120 amp esc" - shouldt this be posted in the fast electric? You can ask a moderator to move it over for you
CA
Brass pipe from the LHS?... nitro fuel fittings from the LHS?...
Brass water fittings from someone like Home Despot, Lowe's or Ace Hardware?...
