IR photos from my Yorkshireman tug
Hi
First photos ever made here are a few pics from my Yorkshireman tug after 1 hours sailing at different speeds
Should be possible to see the shape of the hull
Water is 15°C
Hottest component is the mikroprocessor on the sound module.....next to the sound module is a 7 ch switch. 27°C is still a very low temperature
Here is a photo from the 4 Conrad 60 A ESC. The two ESC is used for the main motors who also has a temp about 52°C. Everything should be OK as long as the temp is below 80°C
Closeup photos on the hottest ESC
One main motor in the boat. Nice hot, but still ok
2nd motor hidden behind some cold wires
The Yorkshireman with all lights turned on
Seen from an other angle
If weather has been colder the contrast between cold and warm would habe been stronger, but still possible to see the 3 bulps in the mast
BR,
Tom
Water is 15°C
BR,
Tom
MO
RE: IR photos from my Yorkshireman tug
The wonders of an infrared camera. You ought to post a regular picture next to the IR picture to give us a better idea what we are seeing.
ORIGINAL: green-boat
BTW: The IR cam is a FLIR 5
