New member motor questions
I am setting up a small vase as a shrimp tank and I am going to light it with LEDs and aerate the water with an electric motor. I figured you guys would be the best people to ask, is there a low power motor I could hook up to a battery like a AA or something that I could leave on 24/7, and if it cant stay on 24/7 what about 12 hours a day? I will have the motor mounted in a foam casing to muffle any noise and vibration, this will be siliconed to the lid I'm making for the vase, I will attach a paddle wheel or small propeller to the motor to churn the surface of the water a little make a small current. What do you guys think would be a good motor for this purpose? Thanks guys.
Think in terms of a motor from a dead CD player. These are nominally 6-12 volts but will turn rather more gently off 1.5-3 volts. They are generally very well built and should have a long continuous run service life as well as having a modest current draw. However, even a low current device will not give long battery life - the more work it has to do, the shorter the battery life.
Thanks for the idea, I'll see if I can find and old CD player. I have rechargeable AA batteries so as long as the battery lasts at least a day that would be good. The paddle wheel/fan blade will only be 1/2 to 1/4 of the way submerged in the water. How long do you think a AA would last or what size battery do you think would be best? I would have never thought of a CD player, thanks again.
How long? No idea, it all depends on the capacity of the AA, the motor itself and the load imposed on it. My original AAs from when I started were 500mAH, the latest were 2500mAH, the newer will last about 6 times as long as the old originals (if they were still around, of course).
On 6 volts, under a reasonable load, a guess would be 250mA, possibly less. With 2500mAH batteries, getting on for 10 hours. At a lower voltage, proportionately less current, a longer run time. This is guesswork about uncharted territory.
You get three motors in a typical CD drive - the spindle motor, the tray drive motor and the head positioning motor. In the ones I have looked at, all have been ordinary brushed DC motors, as times move on, newer ones may have brushless motors, which need a controller.
