blackjack
FL
i know everyone is sick to death of blackjacks but it's what i got. i'm running an iv bag(no bubbles), i'll run it for about 4 mins and then it slowly dies. the engine gets quite hot but theres water coming out the outlets. (it also has a full mod motor in it). also i ran 3 different props on it and got consistently 48.and change mph. i had an x472,x572,and an x470/3, all the props let the motor wind up. i'm assuming that is my hulls limit. any ideas.
ORIGINAL: black talon
I have one done up with every mod. No clutch, 1/4'' shaft all the way, dual aluminum rudder setups, relocated tape on lid radio box set down between rails, gas bag down low next to engine, 1/4 scale steering servo, full mod engine, complete new 2" band pipe setup with water cooled flange and 3" header. It was doing about the same speed 48-50 on a really good run with the X572. Any faster and she'd blow over unless you set it wetter but then it wouldn't do 48 any more so I guess that is about the speed limit for that hull maxxed out.
Thanks Daniel
are you still running a single waterline thru the head and does it run hot?
It runs very cool. Are you still running the water pumps?
Daniel
FL
no,i ditched the clutch,water pump,3/16" cable,throttle setup,hard tank,and went with aeromarine rudders.the head gets to hot to touch.i don't have a temp gun.and i still can't figure why it dies after a couple of laps.
