scale sizing for rc boats
hi
can anyone help with this, the last guys input i dont under stand i need a % so i can take my flash card to copy max that i down loaded from these plans on the fourm thanks rye
http://www.rcgroups.com/forums/showthread.php?t=1012980
CA
Dont bother trying to enlarge those drawings... they are too small..
Ask Joe to email you some better (larger) drawings...
I've done the maths...
26'
26' = 312"
312" @ 1:16 = 49.92"
Drawing at 100% print out measures 1.5625"
49.92" / 1.5625" = 31.9488 times... or 3094.88%
28'
28' = 336"
336" @ 1:16 = 53.76"
Drawing at 100% print out measures 1.71875"
53.76" / 1.71875" = 31.2785 times... or 3027.85%
At about 3000% a 1/32" thick line on the original drawing will be around 1" wide on your enlarged print!..
Better still, ask joe if he can mail you a copy of his original drawings to have enlarged!.
26'
26' = 312"
28'
28' = 336"
hi going ahead with this even if i cant get plans may have some alumium tube welded up with cone noses" to look like pontoon tubes anyway do they make a out board engine that is big enough to power this it will be 48-50" long thanks rye
The image you sent me was 8x10-ish. I scaled it to E-size (34x44) and it's a little blotchy, but you can build if you know what you're doing. It would give you a hull about 26" or so.
A PDF is attached to the e-mail reply. Just ask them to print it on 34x44 (100%) and you should be OK.
Andy
Andy
Toesup,... You need to stop divideing by 1/16
You should be dividing 312" by 16" not 1/16"
The model should only be 19.5" long....
The 28 foot model at 1/16th scale should only be 21" long...
[8D]
[8D]
