Cooling Traxxas EVX-2 16.8 V ESC
Here's something new for you. I have a Traxxas EVX-2 Waterproof 16.8 V. ESC w/BEC along with two Titan 550 motors, all new, that I want to use in the 36" Dumas Chris-Craft Commander Express Cruiser I'm building. My concern is heat! Since this is not the Marine version I would like to give it additional cooling since it will be "cooped up" in the hull of the boat. Any "ideas" or "suggestions" on how I might do this?
BTW, I did ask about removing the existing cooling fins and putting the after market water cooling kit on it and was told "it is not recommended".
Thanks in advance.
Bob
Thanks in advance.
Bob
FL
I am planning to run an EVX2 in my old Wildcat with 2 550 motors-of course the Wildcat is a lighter boat than a Commander so it might not get as hot.Since the EVX has thermal shutdown protection I figure I will just run it and see what happens.You could vent the hull to allow some air circulation which should be easy with a cabin cruiser.
