My K&B floods all the time
Hi guys
First time user here so i don't know if i'm doing this right or not.
Hope someone can help, i got a omega hull with a K&B 67, the fuel tank is
higher then the carbie and it floods all the time, is there a valve or anything that i can
put into the fuel line that will stop this?
TX
RE: My K&B floods all the time
If you cant move the tank to get lower than the carb you can get a small fuel pinch clamp and clamp the fuel line off when not running the engine..check tower hobbies I bet they have some fuel line clamps..could probably use a clothes pin until you can get a good clamp..also make sure you have shut the throttle all the way down when its not running thatll help keep fuel from flooding in
Thank you for that but what about when i try to start it? it normaly floods after first couple turns & locks up, in instructions they say to have fuel screw open 8-8 1/2 turns seems a bit to much only going on my ops40 i had befor that was only 3 turns
TX
That doesnt sound right at all..id start maybee 3 turns out and see how that goes..I bet that greatly helps with the flooding..try it and see how it goes
NB, CANADA
srw is not far,
according to mecoa (K&B) site the HSN should be at 3 1/2 turns out from closed as a starting point.
Dan.
Dan.
Yeah, that's awfully rich for that carb.
On the other problem, yes, the fuel tank is way too high allowing the fuel to siphon into the carb flooding it. You're also placing the CG much higher which can give you handling issues.
I don't know what tank that you're using but Sullivan makes a Vee bottom fuel tank that holds 16 ounces that places it lower in the hull if you've got a mono which is what I'm assuming. That would be a good size anyway for your engine.
Thank you for all your replies i thought as much with the hsn setting and obviesly with exhaust pressure.
As to the tank i made the tank and yeah think that mite be the biggest problem, it is in a mono hull and
the tank sits under the exhaust shaped around it for more fuel capacity holds about 700ml dont know what that
is in ounces....but think i better start with that.[8D]
NB, CANADA
700ml would be 23.6 OZ, that's a big fuel tank depending how big the boat is.
it will give you some good run time, but it also give's you a lot of weight.
Dan.
Dan.
G'd morning fellas hey i come up with an idea this morning to my fuel tank prob.....
If i make a small reciever tank lower than the carbie and discconect the fuel supply line
in between the fuel tank and the reciever tank in between start ups that would keep the small
reciever tank full enough for start up, but not syphon the fuel from the main tank until exhaust pressure
builds up and it starts to flow again.
What do you guys think?
TX
What your wanting to do would probably work but I realy think you would be much better off downsizing the tank a bit and relocating it...
Out of curiosity Olly - if it is just during start up that the motor is flooding - could you adjust the boat stand so the tank is lower than the motor while you try to get her fired.
Would save you the extra hassle of trying to connect fuel lines once she is running.
You're probably right srw1960 but the carbie is only about 11/2in off the bottom of the V.
Thats probably the biggest mistake i made when i built it.So fuel capacity would not be alot to try & keep it under,
If some one could tell me how to put pics on here i could maybe try to show it.
I am just not up to speed with this yet its the first time...and can i just say all of you been great to talk to.
Justaddwata it is to much of an angle, but my fuel supply comes out of the top of my tank so what i thought
is if i disconect the fuel line befor start up let all the fuel run back into the tank and reconect befor
i start the motor the fuel would not syphon through untill the engine either draws on the reciever tank or
the exhaust pressure pushes it through again
Ryan, you've got what was my first though also as at first I was thinking OB tunnel with it having a .67 on it's an inboard mono. I had the same problem with my .45 Microburst even with the 16 ounce Vee tank. The problem is that the carb sets low positioned on the rear of the block instead of up high on the block. Either keeping the hull tilted forward and/or blocking off the fuel flow with something like hemostats or a spring loaded clamp is going to help from letting fuel siphon in when not running.
ORIGINAL: ROADSIDE
Thanks John and all others,
the web address you have sent is what my tank is in shape, but since i made the so called sub tank or reciever tank it solved all my probs.
I made up a tank which holdes about 6cc of fuel lower than the carbie, so when i start the engine, the 6cc tank is full and the main tank fuel
is blowen back into the tank so its not gravety feeding through to the recieving tank, until engine starts & exh pressure pressurises
main tank. All is good it runs I am happy......
