About a CY27 4+HP 27cc
I have a CY27 and the water jacket has 4 water ports/connectors 2 on the very top and 2 on opposite ends on the side( 4 total) . I was wondering if anyone know how to hook up a water line to them? Can I use 1 on the top and one on the side and get 2 small bolts to block the other two,or do I use 2 on the top for pick up water lines and use the 2 on the side to dump the water out of the head?
I would aim to run a pair of cooling lines parallel (if available) - in on the lowest fittings and out on the top.
You could probably get away with a single line in and out - I have yet to overheat a zen or sikk due to the amount of flow. I only have one or two that use pairs.
