New boat project (modification)
Yes, this is a modification (again) This is my latest one http://www.rcuniverse.com/forum/m_9685878/tm.htm
This time, I got myself the navicraft outrage 26cc. And the speed of this thing is pretty good, and the hull is just perfect, detailed wise.
But after a little while running this boat, I saw that the need for a clutch on this thing is a must! Im pretty much solo when im driving my boats.
So, I stripped it! And figured out that this would be a good base for a huge electric motor. It's going to be a KB45-17XL 700kv with 180a esc.
The only problem that I have encountered is that I cant find a coupler from motor to flexy axle! I have looked everywhere, but no luck!
Is there anyone here that can guide me to where I can find a straight coupler. from 6mm to 6.5mm or 5mm to 6.5mm?
The motor in the boat that you see, is not the 700kv one, this is smaller that I tested with.
um, I think you have misunderstod or not read it all
Original this boat comes with a 26cc gas engine without a clutch. Ergo, makes it hard to run alone.
Im quite aware that electric boats dont need a clutch.
ORIGINAL: Ron Olson
There is no reason to use a clutch in an electric boat. You should be able to just drop this in the water and go anytime that you want to. I don't even know where to get one if it needed it.
I have tried that site, they dont have the dimensions I need. And their shipping cost is trough the roof. (for anyone that dont live in US, even if it's just a small item)
ORIGINAL: boatnut
Wickedman,
Try Offshoreelectrics
Wickedman,
Small Parts Inc
W.M. Berg Inc
Stock Drive Products- Sterling Istruments
or Make your own by drilling a short length of brass/aluminum rod to
the proper diameter at each end, then cross drill it and thread the holes for
set screws.
W.M. Berg Inc
set screws.
ahh, just awesome! Thank you so much for those sites, I have now ordered my missing couplings!
Many thanks Umi
Many thanks Umi
ORIGINAL: Umi_Ryuzuki
Small Parts Inc
W.M. Berg Inc
set screws.
Small Parts Inc
W.M. Berg Inc
set screws.
