Painting yellow strips over blue basecoat
DE
I am in the process of painting my boat. The basecoat is a blue, however, i wanted to paint some yellow stripes over top without having them turn green. Im new to using automotive paints for painting so I am unsure how one will lay over the other. Im assuming i would eventually get yellow over the blue with enough coats although I am not sure. The blue paint im using forthe baseis from Sherwin-Williams automotive collection and is a two-in-one base/clear.
ORIGINAL: JawzSS
DE
no im not using a candy.. ok cool, just wanted to make sure. This is my first time using automotive paint.
CA
Not sure if you have any but 1 coat of bright white then your yellow on top. Not to worry if you do not have white, just would cover faster and have a bit more vibrance.
Yellow and red are the worst colors to try and put over a non white base coat. You can put yellow over the blue but it will never cover to show the true yellow. You will be much further ahead if you put on a couple of coats of white before you put the yellow down. In the future, always put your lighter colors on first, preferably a white base coat, then yellows and reds and then mask for the darker colors.
Check out this link... firststatecomposites.com/photo_album.html
The pictures of the yellow and blue hulls were painted the stripe color FIRST. It is MUCH easier to tape off the stripe area you want shown after the stripe color is down. Once taped with a HIGH QUALITY masking, the main base color can be applied. Removing the tape carefully makes for a perfectly sharp tape edge and a perfect white (or yellow in your case) stripe.
I used to paint for a custom autobody shop for years. Still do as a hobby to keep up the skills! Most of the hulls I build leave my shop fully painted with auto basecoat/clearcoat. The link above is just a small example. If you want to talk shop, feel free to call me directly, I'll PM you my number,
