Boat for Pool?
I have a 20x40 pool that I want to get an RC boat for. I've seen some old posts about this but nothing recent. Anyone have any good suggestions? I'm leaning toward the Reef Racer 2 at the moment. I have also seen people suggest the ZigZag and Mini-C.
What are the current "hot" boat suitable for pool use?
Thanks in advance.
Thanks in advance.
My vote is for a Mini -C.. I have 2 of them and we run them in the pool all the time. They are fun little boats to run in a pool! And their steerable outdrive allows them to turn on a dime which is nice in a small area.
DE
ORIGINAL: Visual Perfection
Too bad you werent looking a week ago. I just sold one of mine, perfect condition everything included for $65 shipped!
I do have a few more complete. Let me know if you might be interested and I maybe I can help you out.
Side note..don't go wide open into the wall in the pool...found out its not too good to do that and cracked the hull in a few spots lol..got a little carried away doing laps and crazy turns in the pool and wham! shes all fixed now though. (don't worry if you did get one from me it wouldnt be the one I crashed! )
OK - I got a Mini-C. I just tried it in the pool. The problem I have it it takes a long time to get the boat to plane properly and get up to speed. Anyone have suggestions on possible adjustments to rectify this.
BTW - when the boat is full speed its perfect for my pool and it handles surprisingly well.
Mine won't get on plane if I go wide open from a stop..I have to ease into the throttle then it gets on plane right away.
I have my props on mine adjusted between midway and all the way down and it seems to work great at that setting..try loosening the screws that hold the outdrive and slide it down some..see if that does anything.
ON, CANADA
ORIGINAL: homerlex
What are the current ''hot'' boat suitable for pool use?
Thanks in advance.
Thanks in advance.
How about a sub. Has a camera option too.
http://www3.towerhobbies.com/cgi-bin...&I=LXRYK1&P=ML
Grinder.
ORIGINAL: grinder-RCU
Grinder.
Grinder.
BTW - by not starting WOT it does plane faster but I'd still like to mess with the outdrive height if possible.
Not sure of any tricks.. I did notice mine also doesnt go all the way down, but it seemed to go down far enough to help with the cavitation issue and it gets on plane much easier now. Hopefully you can get yours adjusted well enough to have a good balance between top speed and acceleration.
BTW - my receiver has been acting flaky since I got it. Its been cutting out on occasion. I emailed Horizon and they are sending out a new receiver. I'm very happy with Horizon's customer service.
Ya horizon has GREAT customer service. It is why I keep purchasing boats from them. Every proboat I have purchased has had some issues, but they always come through and take care of the problem for me.
Let us know how the new reciever works out, as I think one of mine is having a few problems as well so I might need to contact them too.
Now the steering servo is shot and HH says its not covered under warranty (dunno why). Anyone have a recommendation for a good replacement (that will hold up better than the stock one)?
