Prop size
ON, CANADA
Looking for a suitable replacement prop for my V 24 One, other then the stock prop i have on it now ..looking for something with a little more lift and speed, any suggestions would be a great help thanks, i should add the boat runs great , had it for 2 years the only problem was a broken flex cable this past weekend but other then that np the boat is all stock
ON, CANADA
Length: 7/8" (22mm)
Diameter: 2-2/3" (65mm)
Shaft Diameter: 0.25" (6.5mm)
Pitch: 4.1 is the prop i have on it now its the stock prop the boat came with, the rest of the boat is stock for now
