Low Cost ESC For Brushed Motor ?
What is the lowest cost reliable reversing 25-35 amp ESC for brushed motors, please ? I once paid $80.00 for a Novak - an outrageous price for such a cheap, simple device - plus it is water-cooled and I had to install a cooling arrangement.... having to water-cool an ESC just doesn't make good sense, as there would be no power dissipation in the unit if it switches the FETs completely on and off as it should. So I also prefer a unit that is fan or air cooled. Is there any such animal available ?
Many people speak well of the Proboat 50A ESC.
There has yet to be a semiconductor made that is a perfect switch - good, yes, but none are perfect. You also have to figure switching time, its short, but during the time that it is neither fully on nor fully off, the transistor is really a resistor, and behaving as such as regards heating.
Oh yes of course, but I personally have built similar switching circuits that powered very heavy loads with very little heating of the switching semis.
ORIGINAL: tri-squire
Probably done that way for the usual reason: cost. That seems to be the chief culprit in the engineering why-did-they's I have encountered over the years ;-)
I too prefer scale boats (and model planes also); I have a 30" Lindberg Line Chris Craft Constellation motor yacht (pictured below) powered by two old-school brushed motors run by a Novak ESC (which I probably oversized in my ignorance when I replaced the old resistive SC with it back in the early '90s). Not a hot-rod, but it will plane off and go around the pond at a fair clip. I also have a 48 year old 36" cabin cruiser that my father built when I was a toddler, which I am restoring and upgrading at this time; and that is the one for which I am seeking an ESC.
