Need help on I.D. of this vintage hydro
I have avintage hydroplane built from a 1970's era kit. Sadly I do not remember the name of the boat or the manufacture of the kit as it was given to me unboxed from a friend.
Details that Iknow about the boat are as follows:
1. It is 28 1/2" L x 14" W and ~ 64 oz.
2. The body is dense epoxy foam withplywood interior sides and interior bottom.
3 It is suitable for use with a .29 to .40 (~5.7cc) glowengine.
4. Ithas a flex drive shaft and a prop specifically designed for the boat.
5. It has a duel fin rudder.
Thank you, and I hope someone will know it's name.
The foam that he used, I don't know what kind it is but it's tough as nails and has a hard shell to it. The wood should only cover the insides of the sponsons.
I built a Hughey .21 'rigger kit way back in 1979-80 and the fit of the wood and quality was fantastic back then.
Is the foam a dark brown color? I've got an idea that it's a Ed Hughey boat from that era ...............The foam that he used, I don't know what kind it is but it's tough as nails and has a hard shell to it. The wood should only cover the insides of the sponsons.............
If anyone is interested, I'm trying to sell it right now on eBay as you see it less any motor.
Thanks Again!
