propeller up grade
TX
I have recently bought a cen boat kit. It came with a cheap plastic propeller 42x1.4 im looking for a metal replacement but I can not find one this size can anyone help The motor pushing it is a cen NT-0.16
Hi
A Octura X442 could work good with your boat. A prather P215 also would work here. A Grupner K42 carbon fiber plastic prop is much cheaper and performs perfectly. All have 3/16" drilled hubs and will have to be sleeved down to the 4mm shaft you have. This is easy to do and works well.
n.h.schmidt
n.h.schmidt
TX
i have the same kit the gray thunder im kinda new to this so i dont know a hole lot where can i get this prop and will i have to do anything to it
Steve's got them in stock but you can ask him if he's still sharpening and balancing them. http://www.offshoreelectrics.com/pro...ries+1.6+Pitch
TX
there is a little lake in a Subdivision off of fm 1736 that i go to but im the only one it would be cool to have someone to run with
TX
Ok cool then. Is that Cen electric or nitro....don't know alot about them....just what I have seen on TH. I am packing an Aquacraft SV 27 nitro.
