Painting Questions
All - I have a few questions regarding primer/paint applications.
1) I finished the hull with Polyester Resin, and the super structure with epoxy resin. Does it matter what kind of paint/primer I user for each? I wasnt sure if acrylic paint will adhear to the Polyester Resin. 2) What's the best primer/pain combination? I'm looking for brands etc... 3) How are most people applying the paint/primer? I have an airbrush kit, but wasnt sure if it could handle the thicker paints. 4) Where's a good place to purchase paint / primer? Thanks in advance -dg |
RE: Painting Questions
Think I'm going to use DuPone Primer no 131s .. any thoughts ?
ddgluck,
I'm pretty sure you can use the DoPont or any auto type primer. To be absolutely sure I suggest you PM TerboBob or Pro 27. They are both very experienced and knowledgeable in nearly all aspects of R/Cing.They post quite often in Airboats Forum.Best to ya!! Gordy |
we have used Krylon paint for years on boats. Depending on what you want to do with the boat and the amount of abuse it will recieve, the Krylon is a lot less expensive.:D
