RCU Forums
-   RC Boats General Discussion (https://www.rcuniverse.com/forum/rc-boats-general-discussion-77/)
-   -   Flex cable rotation (https://www.rcuniverse.com/forum/rc-boats-general-discussion-77/2322846-flex-cable-rotation.html)
More HP 11-06-2004 07:11 PM
Flex cable rotation
Is a flex cable only meant to rotate in one direction? In other words, if it was run backwards, would it unwind?
Thanks, Matt
Hydro Junkie 11-06-2004 08:23 PM
RE: Flex cable rotation
In a word, YES. If you are planning on running a right hand prop, you will either need to find someplace that makes a reversed flex or run a solid shaft. I've heard of reversed flex shafts being available, but i've never seen one. Sorry I can't be of more help[:o]
Ron Olson 11-06-2004 09:26 PM
Octura carries reverse rotation flex cables. They get used on twin or more engined boats that use counter-rotating engines and props. Nope, I've never seen them either. Some of the do-it-yourself Gas boaters use them if they stuff a Chainsaw motor for instance in their hull.
More HP 11-06-2004 09:38 PM
Roger that...
Thanks guys!
