barge power options.. need help
I am building a barge. 24" x 12" made of wood/foam. I need to power it. Was wondering what setup to use. I want to run 2 motors that steer by forward reverse (like a tank)... no rudder. What esc should I use. Which radio? What props for slow moving heavy barge?
Thanks for taking time to help. |
RE: barge power options.. need help
cant give you an exact but i would reccommend a low reving motor with alot of torque. Therefore you can run a larger prop, which will aid in steering.
I have 2 Lathe motors 55 turn. It's the set up of esc, radio, props that I need. Thanks for the input.
