tabletop spray booth plans
Hi, anybody have any plans or ideas or no were to get plans for building a tabletop spray booth?
thanks.[:o] |
RE: tabletop spray booth plans
The January/February issue of Ships in Scale magazine has a construction article of one.
Tug |
Hi,
Check out this link: http://modelpaint.tripod.com/booth2.htm http://modelpaint.tripod.com/images/spray_booth.jpg RiverRaider |
Wow, there is a technique and science to paint booths?
Nice link RiverRaider... Plans? I just duct taped five pieces of foam core poster board together and then mounted a bathroom fan on the back. Then taped a furnace filter over the outlet hole. Does a decent job of venting fumes, but could use more CFM of air movement. The MicroMark paint booth uses a 185cfm fan. That might be a good baseline when looking for fans.;) |
That is one small booth, not hardly big enough for a plastic car or airplane. The 185 cfm would be the bare minimum for anything larger. I would probably look at more in the 250 range
Just do the poster board thing, set it up next to a window and use a 20"box fan.
I like the idea of pulling the air down through the bottom, I was thinking a display rack from a deli or grocery store would make a nice grate. Just cut to fit, would look like a big grill but with a fan underneath hopefully instead of fire but one could just get a big hood filter for an oven, so paint doesnt go directly in the fan. I like this.:D
Quicksilver you could always buy an egg crate diffuser for an overhaed light. They aren't very expensive.,
Tug |
Took me a second I know what you're talking about, very good idea, also good laminar flow characteristics.
I use a squirrel cage blower and motor pulled from an old clothes dryer. Its all bolted together when you pull it, and accepts standard 4" ductwork, 110V, 1 1/4HP Direct Drive. Totally spark-proof and can suck paint straight out of the gun without a compressor.:D YeeeHAW!
