baitboat help(4 pump driven)
1 Attachment(s)
hi guys
ive just purchased a bait boat hull. i[img][/img] i have 2x 1100 gph bilge pumps (forward thrust) and 2x 800 gph (reverse) 4x mtroniks viper marine adjustable speed controllers spektrum DX5 radio set. rc lighting 4 motor mixer The boat is wired as in diagram but i am having trouble getting the boat to be controlled how its supposed to. Is there a way of having the control i would like as in diagram, (i.e forwards/reverse on left stick and left and right by right stick) by using another mixer or V tail mixing. Please help guys as im really stuck |
RE: baitboat help(4 pump driven)
ORIGINAL: jonnie1986 hi guys ive just purchased a bait boat hull. i[img][/img] i have 2x 1100 gph bilge pumps (forward thrust) and 2x 800 gph (reverse) 4x mtroniks viper marine adjustable speed controllers spektrum DX5 radio set. rc lighting 4 motor mixer The boat is wired as in diagram but i am having trouble getting the boat to be controlled how its supposed to. Is there a way of having the control i would like as in diagram, (i.e forwards/reverse on left stick and left and right by right stick) by using another mixer or V tail mixing. Please help guys as im really stuck They are good at moving water, but are very inefficient when used to control the movement of a boat compared to a propeller... plus the weigt of 4 pumps / motors is reducing your bait carrying ability. As you have also found out.. compared with a 'standard' prop and rudder, trying to control a boat with 4 'motors' is over complicating what could be an easy set up. Ditch the 4 bilge pumps, go with two motors / props and mix to get the steering... |
The usual solution with a "standard" boat is two reversible motors, each with its own ESC, connected via a mixer. Two ESCs, plus one two channel mixer.
If the bilge pumps are non-reversible, pair up a forward and reverse, and feed each one via a rectifier diode. That way, the forward motors will respond to a forward signal via its diode, the reverse one to a reverse signal via the other diode. (Assuming brush type DC motors in the pumps). I am not familiar with the mixer you mention, so I might well be making some incorrect assumptions, but the installation does seem to have become overly complex, and needs to be got back to something simpler. |
hi
thanks for replys the boat is pretty big so weight of the 4 pumps is not an issue. i have already purchased the parts, im thinking of ditching the mixer though but istill want to use pumps Were can i get a rectifier diode and how will the steering work? please help guys! any diagrams would be appriciated |
Does the DX5 have the ability to mix channels?.. if so...
Do away with the mixer in the boat.. Plug all 4 ESC's in to the Rx (disable 3 out of the 4 BEC's from the ESC's) You should be able to electronically 'mix' the operation of each motor at the Tx... |
I would consider ganging pumps 1 and 2 on a single channel.
Make them on or off using micro switches. Use them as bow thrusters. Pump 1 thrusts left, pump 2 thrusts right. That will allow you to direct the bow. Pump 3 and 4 can be used for foward thrust and help with steering. If they are mounted with a slight thrust angle toward the center line, then when either one is run by itself it will produce a steering thrust vector along with its offset thrust. |
Look at
http://www.maplin.co.uk/Search.aspx?menuno=12480 then go down the page to UK59P which should be capable of carrying the current. They have a storefinder at the bottom of the Home page, so you should be able to determine your nearest store. Various UK suppliers do 2 channel mixers to work with simple TXs. |
Do away with the mixer in the boat.. Plug all 4 ESC's in to the Rx (disable 3 out of the 4 BEC's from the ESC's) You should be able to electronically 'mix' the operation of each motor at the Tx... hi mate how do i do this??? |
| All times are GMT -8. The time now is 08:44 AM. |
