tmaxx 2.5 not running well after easy roll
I had rebuilt the engine, and put this piston in facing the correct way, as it was not facing the right way, and was running like it should, went driving in some dirt
and rolled it quite a few times, then on one roll it made a bit of a knocking sound as it cut out, and since then has not worked well, has been taken apart and cleaned
as the air filer ate some dirt and was not working correctly after cleaning
I have been able to get it to run a bit, but at low rpm it has this weird bogging like, but it does not seem to be something I can tune out
a few times I got it to work after forcing the engine to run (run it at max revs till it quits its weird bogging)
Maybe a month later or so and Now I cant even get it to run long, and doesn't even spin the clutch bell (unless I hit the starter button while giving it full throttle)
It does have a TRX 2.5
If you have any questions just ask
Higgins909
Higgins909
