Question about locktite?
I have a 1/10 scale on road nitro rc. I know blue locktite taies 24hrs to fully cure. Is waiting that full 24hrs a necessity to prevent engine from moving. If anyone has experience with not waiting the full 24hrs but still having no issues with motor moving which usually results in spur gear grinding for me, can yall please let me know whats a more acceptable time besides the 24hrs, if there is one?
Full Pay Gaming (05-11-2022)
I was having issue with motor moving and spur gear being destroyed. So I used red locktite on motor mounts and blue on motor screws. Been a few days and everything has been ok.
Never use red loctite on RC stuff h less you plan on torching the thing apart. Red is permanent and heat is the only thing that will break it loose. again - if you tighten your screws with everything good and warm, they shouldn’t come loose. My motor mounts never come loose, and all I run are modified engines.
Only reason I used red is because I didnt plan to remove motor from mounts. If I need to work on engine at all I can still remove it from chassis and motor mounts arent blocking access to anything so figured it wouldnt be a problem. I was just ready to actually be able to play with cars instead of stripping gears back 2 back.
By warm, I mean having driven the model for awhile - 15-20 minutes of good romping. This ensures the crankcase and motor mounts are warm which makes the metal expand. Heat from the engine transfers to the surrounding metal that is in solid contact with the engine. Aluminum gears up quickly and tends to expand quite a bit which loosens the bold in the screws. Snugging them down when it’s expanded helps the screws retain their tension through several heat cycles.
Full Pay Gaming (05-16-2022)
