Vintage O.S. .21 Storage & Compression
Hey All,
I have a very old O.S. .21 in an old Kyosho Vanning that I've recently become concerned about. The car & engine have been shelf-residents since new, but I recently noticed it's become much more difficult to spin the crank by hand & it feels like it won't be long before there's no compression left at all. Admittedly I haven't done much of anything to protect it from wear that comes just from sitting idle for such a long time. Is there anything that can be done to reverse the damage that's already been done? What about just to prevent it from getting worse? While it's unlikely I'll ever opt to run this one, I would like to retain the option, or at least be able to say that the engine has some life left in it should I ever decide to sell. Thanks! |
If the engine has been run at all, the residual oil in the engine will dry out over time making a sticky gunk that freezes things up. This isn’t a bad thing and it certainly won’t remove any life from the engine unless the oil contained in the engine was synthetic oil only. If the engine is new and never run, the factory used a light oil that too will dry out over time. A simple fix for any of this would be to flush the engine with acetone, drain and dry, and re-oil with a good storage oil. I prefer to use Dexron (any variant is fine) automatic transmission fluid (ATF). I use a liberal amount to thoroughly coat the inside of the engine, crankshaft, and bearings. Remove excess and button it back up. This will keep the engine smooth and limber for decades to come. |
Like any nitro motor, store it with the piston at bdc.
The engine has definitely never been run. I will pick up some acetone. Thanks again for the tips!
Originally Posted by kyoshofan88
(Post 12567143)
If I may ask - Why have it as a shelf queen? |
