Can you mix different weights of shock oil and diff fluid?
OH
Does 40w + 50w in equal parts = 45w?
If so is it a bad idea to mix different manufacturers products?
RE: Can you mix different weights of shock oil and diff fluid?
if your talking about silicone shock oils then yes you can mix different weights and you should be able to mix different brands as well aslong as there both silicone based.
