Hey new guy here..
Old 05-12-2011, 02:16 PM
Seanhasabuggy
Default Hey new guy here..
Well not new, just new to the forum. Have a question about pull starts. Can you "clock" them so the pull string is in a different spot? Reason i ask is, i have an exceed buggy, had a vx16 motor on it, i upgraded to a vx18 motor, fit perfectly, clutch and mounts and exhuast swapped over no problem. But the pull start string gets wedged between the wing mount and the throttle linkage.
Sean.
Old 05-12-2011, 11:06 PM
Foxy
Foxy's Avatar
Default RE: Hey new guy here..
If you are asking if this is a mod that the car manufacturers cater for, then no. However, if you're asking if it can be done, well sure, anything CAN be done.
Post a pic of the problem and we'll try to help you think of something.
Old 05-13-2011, 03:12 AM
Seanhasabuggy
i will once the new pullstart comes lol
Old 05-13-2011, 05:14 AM
TIGER76
TIGER76's Avatar
welcome to RCU m8 plenty of good ideals and advice on here
Like foxy says post up some pics and we will see if we can help out [8D]
Old 05-13-2011, 05:23 AM
Seanhasabuggy
thanks! the new pull start should be here by next week. *sigh* 3rd tank on the new engine and the cord pulled right out..
Old 05-13-2011, 06:19 AM
DaveG55
DaveG55's Avatar
First, hello and welcome.
Most pull starts I've seen are held on with 3 or 4 screws. Many are able to be turned to bolt up in different positions that are basically 1/4 turn apart. Some are not though due to the screw hole patern or backplate design. So whether or not yours can be turned depends on those things.
Also, pull starts can be dissassembled and repaired. The can be a bit tricky since the spring has to be rewound and the parts are small but it's definatly doable.
To keep the string from pulling out you have to be careful to NOT fully extend it when starting the engine. Only pull the string 2/3 - 3/4 of the way out. Pulling to the stop point will lead to the cord pulling out or something else breaking in the PS
Old 05-13-2011, 06:30 AM
Seanhasabuggy
yeah mine has 4 screws and looks to be square. so ill see when the new one comes. oh i didnt pull it all the way, i only go maybe 4-5 inchs of pull. but it didnt retract, so i pulled a little more.. and yeah. lol
and thanks!
Old 05-20-2011, 10:40 AM
Seanhasabuggy
here she is! got the new pull start on, was able to mount it rotated 90 degrees towards the passenger side of the car. out of the way of the throttle linkage
*edit* forgot to post a pic of the area i was havin an issue with (put a bigger motor in)
lookin down onto the motor the linkage is on the left, the pull start was getting wedged between the linkage and the wing mount.
ID:	1611772   Click image for larger version
ID:	1611773   Click image for larger version
ID:	1611774   Click image for larger version
ID:	1611775   Click image for larger version
Copyright © 2021 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
