Turbocharged nitro engines
#101
Banned
RE: Turbocharged nitro engines
ORIGINAL: supertib
Are you really this ignorant of a person ?
ORIGINAL: TheKennyKiller
Yeah yeah yeah, I know you guys love to tackle the big issues.
I just think it's funny how far you guys will go to not only one up the other guy but also just to prove yourself right. Even though there is no name calling it's pretty easy to see that there is no love lost between some of the participants in these type of threads. Anyway, seeing how desperate you guys are to prove your point is kinda entertaining so like I said earlier, carry on.
BTW I love getting one star ratings, it's like giving an attention seeking little boy an ice-cream.
ORIGINAL: supertib
You shouldn't be so fast to start to criticizing this thread.....we are only having a peaceful open forum discussion about an advanced technical subject related to nitro RC's....I don't see any name calling or any other reasons for anyone to complain....... these types of discussions do no harm at all, and in the long run will offer a rich source of technical information your not going to find many other places.......Unlike many others I am actually capable of building and testing the apparatus needed to test the theories of boosting a nitro engine.....If anyone is disinterested in nitro engine theory then they should just not read the thread and allow us other gear heads to do our thing without all the complexity added by unneeded drama....For me this has nothing to do with proving a point, or at least not in the connotation you want to apply ...I am driven to try these sorts of things because it is my passion, my hobby and my business..... Anything new I can try is like a treat for me, as I thoroughly enjoy what I do.......building and dyno testing a way to boost these nitro engines is an awesome project that I would do whether someone was egging me on or not.....A little extra drama on the forums bantering back and forth in good nature just makes the results all that much more interesting..............Just wait guys..... this entire project is going to be interesting for anyone who has any sort of fascination with nitro engines.......The thing you need to remember, that is anyone can make boost work on these engines it is going to be someone like me...I bring a whole pile more experience, knowledge and resource then the guys you see on youtube bolting a RB innovations Supercharger onto their T-Maxx ........... So don't count this theory out untill you take the time to know the players in the game..... What I got planned is a whole different ballgame then what anyone else has done......
The lengths people will go to just to prove a point. Guys... wouldn't it just be better to agree to disagree? Oh crap, I forgot I was on RCU for a second... Carry on.
#102
ORIGINAL: supertib
it is impossible for the fuel pressure to be lower then the intake pressure..
the fuel tank will always be at a higher pressure then the engines intake.,...its the simple mechanics behind these engines... as no matter how much air we cram down the carb the exhaust will always have substantially more pressure then the intake side of the engine..... ........
you do realize that ''Boost'' is only air right ? and your must realize that if we increase the intake air volume by 30% we will also increase the exhaust volume by 30% as well................so no matter how much air we suck into the engine the exhaust pressure will always be proportionately as strong ... We could triple the volume of air going into that carb and the fuel system will always keep working just the same...........
Hummmm... I know that the exhaust flow is the same as the intake flow,(excluding nitrous) but I thought the muffler bleed off pressure through the stinger. So naturally I assumed that it would be slightly lower
I'm use to full size engines that are lucky to see 1psi in the exhaust system
I'm just assuming here...
the exhaust pulses right? So it's continually changing pressure, does the pulse peak over intake pressure. Or peak to intake pressure?
And I'm assuming that traped pressure in the exhaust is what makes the air seal around the exhaust port when the piston is down?
If that's correct, regardless of valves u should have no problems with forced induction right?
Say if the exhaust pressure is the same as the intake, no boost would be lost out of the exhaust port because of the 2 high pressure fronts hitting each other...... See all I needed was a few drinks to slow my thoughts lol
I got to thinking u could seal the carbys slide the same way, just drill a small hole up the housing to the slides bush, pump boost up there and u wouldent have to worry about fuel been Bowen out the bush, only air would.
#103
Hey just thinking, the fuel system is going to need strengthening, if ur race engines are poping the tank lid, a decent working turbo setup will be even worse and might pop fuel lines.... I've found the muffler hose to fuel tank has been the most problematic for me, I can only assume its because of the heat, this is going to be more of a problem with a turbo.
Might be worth fitting some of those micro hose clamps
#104
My Feedback: (9)
GA
It would probably bust the tank before the lines,since you two are done having a "conversation" supertib just needs to test it now! I think It will work I just dont know how well.
#106
ORIGINAL: phmaximus
#109
No, i just finished putting it together, everything right down to the radios on that plane are new, nothing has ever been runned, still waiting on running gear in the mail, a month and a half and still nothing
#115
Bump!
It seems rc turbo tech has moved forward a bit since this thread was made, and last bumped. I just bought myself one of these bad boys.....
http://www.turbokeychains.com/product/ge-s2/
Along with one of their stainless down pipes.....
https://www.shapeways.com/product/UN...ionId=58042134
I'm gonna give this a shot on my trx 3.3 swapped asc rc10gt. It doesn't look like the turbo and down pipe will be here for another week or so. But if anyone is interested I'll post some update pics as I go.
#116
Bump!
#117
I know its a toy you goof ball, a nitro rc car is a toy for chirsts sake. The "picture of a pipe" as you call it is a 3d drawing of a part that is printed in brass infused stainless steel, and isn't anything but a representation of the part I'm going to get. I'm doing it to satisfy my own curiosity, and because I can. I'm not interested in your opinion of how or how it isn't going to work. Thanks though.
Edit: Wait, I think you have the wrong idea of what I'm trying to do here.
#118
It wont work. Ive bought those keychains and bench ran them and even used some custom impellers and other modifications but could never get it to make boost.
And same with our 2 strokes ive experimented a bit and tried to blow compressed air into a running engine but tuning was a hassel and the carb was never right
But one fellow is set on trying it anyway:
http://www.rcuniverse.com/forum/rc-c...ke-rc-car.html
http://www.rcgroups.com/forums/showthread.php?t=2606766
