xerun 150, need more help. won't run sensorless.
FL
my xerun 150 runs fine now that I followed syko's advice and calibrated the throttle settings -- idle, neutral and full throttle. but it refuses to run sensored. i'm using the hobbyking sensor cable, which does fit. the motor is a turnigy 4 pole 2350kv sensored buggy/truggy motor.... thanks. wrong cable maybe? the wires, by the way, are color matched and the motor spins in the right direction when sensorless. so I don't think it's the wires being crossed up.
For sensored operation the main wires MUST be A to A, B to B, C to C, double check that again.
Also, you will have to re-do the calibration when switching from sensorless to sensored and vice versa.
Let me know how it goes after checking the connection and re-calibrating.
just to note the colors might not match up on the wires as turnigy, and Hobbywing are different companies
should go straight off the motor, and ESC and match them like foxy said as they should be labeled clearly
