Motor Pinion Gear Sizes
Old 04-29-2014, 06:23 AM
R32GolfTA06
Default Motor Pinion Gear Sizes
Hi guys, can someone please tell me re difference it makes between putting a pinion gear with 19 teeth on a car compared to one with 30 teeth? Do pinion gears with more teeth gear a car up to go faster or slower or how does it work?
Cheers
Old 04-29-2014, 09:56 AM
R32GolfTA06
anyone....
Old 04-29-2014, 12:36 PM
nitroexpress
nitroexpress's Avatar
http://www.radiocontrolinfo.com/ElectricCar/gearing.php
Old 04-29-2014, 07:18 PM
cumquat
cumquat's Avatar
bigger pinion/smaller spur = faster/less torque
smaller pinion/bigger spur = slower/more torque
Old 04-29-2014, 11:03 PM
R32GolfTA06
thanks for the info guys.. but just to be clear.. there are a lot of teeth variations.. I get the difference between 48p and 64p but was wondering what difference say I pinion gear with 20 teth would do over one with 21 teeth... the differences are so small..why would it matter?
Old 04-30-2014, 08:25 AM
cumquat
cumquat's Avatar
well, to really specify the difference you'd have to look at a specific setup. lets use the rc10t4.2 with 4" tires, an 78 tooth spur and a tekin 17.5t 2400kv motor (used in ROAR stock spec racing). with this setup an 2s, a 20t pinion will move the truck at 20.84 MPH and a 21t pinion will do 21.88 MPH. the purpose is for fine tuning and on high speed setups (or vehicles with no gearbox) the difference of 1 tooth on the pinion can mean as much as 5 MPH which could be what makes the motor fry.
Old 04-30-2014, 10:30 AM
R32GolfTA06
ah ok I see.. I don't think I need to be so specific as I have a drift chassis
