2100mah lipo battery
Hey Guys,
I know lipo questions get asked a lot and i'm sure you're getting sick of answering them but i really wanted to double check before i burnt my house down.
I've got the below lipo battery - 7.4v's and 2100mah. Currently i've just been setting my charger for 2.1amps and 7.4 volts - doing a balance charge and it will take between 20mins and 40 minutes depending how low the battery is. Looking on the web though, this battery is listed as 5c (25c on the battery?) - does this mean i could set my amps to a ridiculous amount? like 10.5?!
Really quite dubious about doing this - always thought we just set the charger to what it is on the battery and thats it.
http://www.probuild-uk.co.uk/image/c...00-500x500.jpg
Any help would be much appreciated,
Tom.
Tom.
There are Lipos that are capable of being charged faster than 1C. If they are this will be noted separately from the normal discharge c-rating. The picture you linked to does say "5C charge", does your battery say "5C charge" on it as well? If your particular Lipo doesn't say "5C charge" on it I would continue charging at 1C. I currently do not have any Lipos capable of charging faster than 1C but if I had a 5C pack I think I'd try 2C out and see how the pack reacts temp wise. I probably wouldn't go past 3C just because IN MY MIND (don't know if true) that would put more stress on it and possibly decrease the lifespan.
I agree. Also, you DO have a LIPO charger, not a NiCd charger? THAT is what will burn your house down.
Be sure to use the Storage function on your charger, too. Don't leave your LIPOs fully charged, nor discharged, for long. It will shorten their useful life. The Storage function will charge the pack to 3.8V/cell, a LIPO's "resting voltage".
Oh, and the "25C" listed on the battery label is it's DIScharge rating. Generally you multiply that figure with the pack's capacity to give you the max Amp output a pack can do. However, these ratings vary widely across manufacturers, and are mainly useful comparing packs made by the same maker.
Hey guys, thanks for your help. I didn't actually know about the 'resting charge' EXT2Rob - i'll make sure i do that in future.
And yes i have a lipo charger, cost me like £60-70 so it better do me well. I'll try it at 2C tonight in a lipo bag and like overdrive suggested, check temps.
Thanks!
Thanks!
Don't be that afraid of lipo batteries, they are safe, the fires come from using NIMH chargers or charging batteries that are puffed up like marshmallows or shorted out.
It is wise to charge only when you are nearby, and obviously put it where there isn't a bunch of fabric around.
I charge 1c-2c max.
I charge 1c-2c max.
