Nitro engine lrp zr.28 spec 3 engine
Old 08-18-2014, 11:39 PM
dan rox 90
Default Nitro engine lrp zr.28 spec 3 engine
Hello guys, to I ran this engine and the carborater retainer screw came out and I can find anything on the web about it. Can you guys find any lrp carb retainers? I did find a retainer for the DYN0952 DYNAMITE Carburetor, isn't that the same engine basically ?
http://www.gravesrc.com/dyn0952-dyna...t-mach-28.html
Thanks.
Old 08-20-2014, 03:54 AM
dan rox 90
Anyone please!?
any help much appreciated
Old 08-20-2014, 10:10 AM
nitroexpress
nitroexpress's Avatar
https://www.lrp.cc/en/products/nitro...teile/details/
Don't see this part available in US. Another brand would probably fit, maybe.
http://www.rcuniverse.com/forum/car-...r-38390-a.html
Old 08-20-2014, 02:18 PM
dan rox 90
What does the retainer do? And how does it work like does it just screw in ?
i think that this retainer will be okay it looks the same as the lrp one...
Old 08-20-2014, 02:32 PM
nitroexpress
Take off the carb. Loosen the carb retainer screw. Slide the assembly into place. The carb throat will fit into the middle of the retainer and be clamped tight when the screw is tightened.
Old 08-21-2014, 12:13 AM
dan rox 90
So do you guys think that this carb retainer will fit?
Old 08-22-2014, 09:52 AM
HerrSavage
Yes - the Dynamite Mach 28, Losi 454, and LRP Spec 3 are all very similar. Identical blocks, carbs, etc.. The Mach just has a different sleeve - 2 less ports.. - and cooling head.. The LRP Spec 3 and Losi 454 are identical btw - except the color..
