Traxxas jato 3.3 help please
Old 10-04-2014, 11:35 AM
Camo_cowboy84's Avatar
Default Traxxas jato 3.3 help please
I just got a traxxas jato 3.3 and im having an issue it fires up fine its when i take off it bogs a little bit but then takes off like a bat outta hell any suggestions would be greatly appreciated thank you
Old 10-04-2014, 11:41 AM
jkdv8's Avatar
Need to break it in if its new then tune it. If it's used just needs a proper tune and/or new glow plug.
Old 10-04-2014, 11:48 AM
Its used ill try a new glow plug and see if i can tune it better thanks
Old 10-04-2014, 12:26 PM
jkdv8's Avatar
No problem.
Old 10-05-2014, 07:01 PM
1QwkSport2.5r's Avatar
If from idle to WOT its doggy at first then winds up and screams (cleans out), the low end is too rich. If you lean it down and it cuts out going from idle to WOT it's too lean. I'd tune it first. If it won't run crisp from idle to WOT, then look to your fuel and glow plug. If the fuel is fresh then replace the glow plug. Usually if a plug is bad, it won't idle for beans and/or it will quit a lot. The element should be silver in color. If it's a silver-gray color you're still in the ballpark. If the element is any other color than silver or silver-gray, it's probably time to replace it. If none of this cures the trouble, check the piston/liner fit. Look brought exhaust port at piston. There should be a shiny band on the side of the piston at the top. If the whole side of the piston is a dull color, the piston fitment is worn out and will need replacement most likely.
Old 10-06-2014, 07:52 AM
Thanks quick sport i put a brand new glow plug in and tuned my lsn a little and it takes from dead stop to WOT awesomely thanks again
Old 10-06-2014, 08:40 AM
As wacky as it sounds, you can tell how your engine is running by "reading" your glow plug. Much like spark plugs in a full size car engine.
Glad you got her running better.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
