Need brushless motor advice
I have a team associated sc10 truck with the traxxis velineon motor. The problem is as long as it is on the stand the rear wheels will spin fine but once you put weight on the wheels it just jumps and won't move any help is greatly appreciated. I recently replace some bearings in the differential thinking that was the problem but it wasn't call or text 601-297-7786
It's probably time to start diagnosing the drive line outside in. I would start with the slipper clutch to make sure its not loose....put vehicle on your lap and hand turn the spur gear while preventing vehicle from moving forward. Look to see if the spur gear and slipper plate move together. Next, move to the wheels and check the pins inside the hex adapters. Pinion gear grub screw...tightened? If it's not any of these areas, then I would start taking apart the tranny.
I'm not sure which model of SC10 you have. Is the SC10 a ball diff or geared diff? If it's a ball diff...your locking t-nut/thrust bolt may be loose.
When you say you put weight on the wheels...you have your vehicle on the ground w/ throttle being applied? What noises, if any, are being made?
When I set it on the ground it makes a grinding noise and jumps I replaced all the bearings in the tranny last night and still no change the spur gear is new also tightened the clutch down and back it off a round and a half.
My past experiences with a "grinding" noise is my gear diff "spider gears" somehow are not meshing correctly.
My diff screws work their way loose every once in a while causing the case to widen; making the spider gears lose their mesh.
