Tlr 22 3.0
Tlr 22 3.0
I was inquiring on help with setup with my 22 3.0 . I race at a clay mid to large indoor track 2wheel MOD 8.5 turn motor . It is predominately race with associate cars. So I'm on my own with setup and I'm lost. I get smoked a lot and I have a lot of traction roll. starting to not be fun anymore any help at all would be appreciated. Thank you in advance.
Hi Red! I'm not a racer, but I'll try to help. If you're getting traction rolls, try giving the wheels a couple of degrees of negative camber. Shorten the upper suspension links with a few turns of the turnbuckles. This will tilt the top of the tires in, lifting the bottom outside edge slightly, allowing the tire to slide a little more. Those race buggies have tons of tuning adjustments, so look up tuning how-to's on YouTube to learn about what they are and how to adjust them. Get an RPM camber gauge for accuracy. Two degrees negative should do it.
