Need help with ESC
Need help with ESC
I bought some waterproof brushless combo (ESC+motor)
I think there is a problem with setting in this ESC because
- Backward has much acceleration than going forward.
- If I change motor setting to normal, the car won't go forward
- If I turn off the transmitter first, the car will go forward slowly
- Weird throttle (unstable)
here is my ESC instruction
Have the transmitter's servo reversing switch to "REV" and re-calibrate.
Easy way to fix that is to switch any to motor wires aroung which will make the motor run tne other way. So reverse will be forward and forward will be revirse. Now farward will have tne power revetse had will still need to switch the rev toggle on controller
