Baja 30cc buggy problems
Hi all just got a new Baja 30cc don't know much about it but having a few problems with it as it dose start and run but after a while it just stalls. Dose anyone have an idea of why this is. The motor dose get hot but when cools down works again then just stalls again, haven't even been able to run it in yet coz this always happens.
When it dies does it have spark and/or fuel? There could be a variety of things but knowing what is lacking when it dies would help us point you in the right direction. And how long is after a while? 10 seconds? half a tank of gas?
if you have to wait 5-10 minutes before it will start again after stalling, it could be a bad ignition coil. I know I had a Volvo once that would start and run fine until it got warmed up and then the coil stopped working.
Run it again, after it dies take out the spark plug and put the tip onto a metal part (motor) and have someone pull start it while you watch for spark. If no spark, then the coil is bad. Good thing is, they are cheap. A coil for my 1/5 exceed was $12
The coil was my first thought as well. Not sure if that motor uses the magnets on a flywheel like some of the small engines do but if you see rust or buildup on the fly wheel points or the pick up for the coil then gently sand them until shiny to make the signal better. If that doesn't work then you are in need of a part. Gas motor repair is just a matter of finding were the signal ends in the system and repairing that part. Once you know the path that electricity/gas/physical force takes then its just a matter of footwork to find were it fails if that makes sense. Being able to visualize a working system in it's entirety is how most good mechanics function, its hard. i worked on cars professionally for years and now i hate fixing them lol
