Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Car General Discussions
Reload this Page >
Need Help On Nitro OFNA Starter Box For Nitro Tc3
Old 09-28-2003, 05:15 PM
rickyq2004
Default Need Help On Nitro OFNA Starter Box For Nitro Tc3
hi i really need anyones help i just need to know how to use my ofna nitro starter box with my nitro tc3
Old 09-28-2003, 06:10 PM
Natesully
Default RE: Need Help On Nitro OFNA Starter Box For Nitro Tc3
Uhhhh.... Make shure the wheel is turned the right way, put the car on it, and push down?
Or are you having some kind of problem with that?
Old 09-28-2003, 07:35 PM
ZipZap
First, make sure you got the model that's made for the TC3. It's the only OFNA model with a slot far enough back towards the plunger to accomodate the positioning of the TC3 flywheel. It's called the Multi-Box (P/N 10246 or 10247)
Second, make sure that the starter wheel is in the correct slot for the TC3. I have the OFNA box (for the TC3) and I had to take it apart and rebuild it with the starter wheel in the right slot. There should be a diagram that came in the box that shows the rear slot set-up.
It takes a bit of time to figure out what needs to come out of the box, and what order to put them back in. Just take your time. If you got it from a LHS, take it in and have them help you through it.
