Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Car General Discussions
Reload this Page >
Redcat twister same as Traxxas rustler?
Old 08-24-2021, 02:27 PM
Trickey27
Default Redcat twister same as Traxxas rustler?
Recently came across and old redcat twister xrg. Been looking up as much info on parts and troubleshooting as it’s pretty rusty and runs rough. Then it occurred to me that the Traxxas rustler looks identical. Anyone know if these parts would be interchangeable or not?
Old 09-01-2021, 08:28 AM
tejotasbd
Some parts might be close enough to fit, but from pix I see nothing identical. - which rustler parts are you looking to put on the redcat?
Old 09-06-2021, 05:19 PM
seedygreenute
I have the xb ( buggy version ) also sold as the HBX Quakewave .
Metal diff is a must have !
Old 09-07-2021, 05:05 AM
RustyUs
RustyUs's Avatar
That thing looks like a hybrid of Team Associated T4, Thunder Tiger Phoenix, Losi XXT and something else combined and sold as a Redcat Racing Twister. The steering rack, servo saver, front bulkhead, top plate, arms, shock towers, steering/caster blocks, rear hub carriers, slipper, servo arm, chassis u-brace, and servo mounts scream RC10T4 at me. Download the manuals and you'll see what I'm talking about.
https://www.manualslib.com/download/...ister-Xtg.html
https://img2.associatedelectrics.com...tt4_manual.pdf
Old 09-07-2021, 07:19 AM
seedygreenute
I believe you are right Rusty ! I watched a video of a guy who swapped out some of the front end with TA parts ( buggy version ) .
My Buggy has a HPI E-Firestorm diff/gearbox ( 1 screw boss on the case needed to be shortened for the wing mount ) !
Old 09-22-2021, 08:48 AM
rhysfaulknerhere
I'm painfully slow at moving things around in Matter Control. Took me hours to cut; paste, and juggle shapes into something that works like a cover for these power supplies..
Old 05-02-2022, 04:06 PM
twisterXTG
Hey I just got my Twister working again also. Its pretty fast. I have the truggy version. Do you know the easiest way to upgrade the rear tires? I dont think these wheels are the standard hex size, but I really dont want to do any complicated mods, just want to put a better tire on. Thanks for any info.
Old 05-03-2022, 02:46 AM
RustyUs
RustyUs's Avatar
You should be able to put a clamping hex adaptor on the rear axle.
A good medium compound tire with large lugs...
Pro-Line 2.2 Trencher
Or, Pro-Line's Gladiator if you can find them (discontinued).
twisterXTG (05-03-2022)
Old 05-03-2022, 04:05 AM
twisterXTG
Rusty thanks so much I will take a look at that clamping adapter. Looks like a perfect solution! Also I did look at the trencher but the only thing is that I was hoping to just get a tire and wheel already glued and ready to go. If I have i glue I guess I can just reuse my existing rim. But not sure the trencher tire will fit, my rim is like 2.35 inches in diameter.
Old 03-22-2023, 06:44 PM
Jonathan_N
Default Warning about Manualslib
Be careful with manualsib.com. VirusTotal turned up completely clean but I narrowly avoided being phished by a Microsoft Support scam.
I can’t post urls but you can find the post I quoted. If multiple people visit this site without issues, I’ll remove this reply, just wanted to make everyone aware.
