M2c xmaxx axle extensions
If you purchased the M2C axle extenders,,,you can’t use the stock TRAXXAS wheel nuts. They are a different thread pattern,,,,HOWEVER,,I Found you can use the LOSI 17mm wheel nuts,,,,so I’m assuming the M2C axle extenders are a fine thread,,,,I’m using the LOSI wheel nuts and work perfectly ….I Got mine from KINGHEADZ.com. They have opened and closed wheel nuts,,,TAZZZZ…..🇺🇸👈🚘
