TC3 issues
Working on an Associated TC3 this evening. Was going to install an esc, motor, rx.
Actually had the motor installed. Realized the way I had it the sensor port was covered. Pulled it back out. Looked at it closer and noticed that the motor lead connectors looked loose. I take the end off to see if I can see any problems. Realize it's dirty as heck so I pull the rotor out and spray it down with electrical cleaner. Put it back together; never figured out why it felt loose. Figure what the heck, lets see if it works anyhow. Start to reassemble and I lose a tiny nut. Either on the floor or table. Spend a good 15 looking for it. Another 15 looking for a replacement. Find one finally. Realize the other nut is pretty chewed up, wish I had the one I lost so I could replace the chewed up one. Look on floor some more, no deal. Decide maybe this car wasn't meant to move today. Clean up a little, find an odd piece of broken plastic. Realize the esc that's attached to the motor in question has a broken case. Great.
Change direction, had an rx crap out the other day, my kid said it got wet. Thought I'd apply some conformal coating to the Rx I was going to put in the TC3. That goes ok.
Clean up some more, look for the nut again. Find a grub screw for a pinion. On the floor. Unreal, hadn't even known I lost a grub screw. Earlier when I was picking out a pinion of course there were 3 or 4 without grub screws, lol. Then I found the nut. Woo hoo.
Go back to the Rx, coat the opposite side. Notice the case is cracked and I think that I'll grab the case from the Rx that crapped out and switch them. So I do that and notice the tiny screws from the original are just a little nicer than the ones from the better case. Go to get them off the original case and drop one. Just shoot me. Of course I can't find it. Not an issue, I have spares due to the crapped out Rx. But seriously, just shoot me.
I briefly entertained the idea of VTA racing. I just have too much shtuff going on, I can't commit to racing on Sundays which is game day in the soccer leagues I coach in.
BUT, I really like the VTA look, so that part stuck. Sadly I have way too many 25.5 motors sitting around. Although now that I think about it, maybe that's what I should stick in the TC3. Then my niece could drive it.
i wasn't going to race VTA i just wanted to build one to drive and fart around with. ended up with a Protoform PFM-10 body and an 8.5 motor. handles good but it's to fast to drive anywhere but large empty parking lots. and that's just kinda boring.
i was thinking of slowing it down a bit (i think i have a 13.5 motor laying around) and put a truck body on it and make a sport truck that i could drive in the street in front of my house.. but i can't find the body i want (more HPI problems) so iv also been kicking around the idea of keeping the 8.5 motor but using a VTA body, wheels/tires and having something that's probably lively to drive.
iv also entertained the thought of making it a drift car, but i think id get bored with that
im looking specifically for the Venom T-10 body
https://www.hpiracing.com/en/part/17500
or the Silverado is a second option
https://www.hpiracing.com/en/part/7401
not sure how well it would fit a modern TC (i think its more for a wide pan car) but Bolink (now RJ Speed) made a GMC Syclone body back in the 90's. was on the hunt for one of those back in the late 90's but never found one.
suburban_hooligan (11-23-2022)
@suburban_hooligan thought of you when I saw this VW truck shell
https://www.aliexpress.us/item/32568...andl_shipto=US
Clean up some more, look for the nut again. Find a grub screw for a pinion blacktiedetailing. On the floor. Unreal, hadn't even known I lost a grub screw. Earlier when I was picking out a pinion of course there were 3 or 4 without grub screws, lol. Then I found the nut. Woo hoo.
that's a C10 body that was brought up earlier in this thread. it's a cool body, and you can still get them from Horizon Hobby's website (although they are pricey!)
