Malibu R/C 1/10 General Lee
Old 01-30-2023, 01:52 PM
Totaldoom21
Default Malibu R/C 1/10 General Lee
Hi guys, I recently dug out of my attic an old 1/10 Walmart general lee and tried to run it but found that after driving around a little bit it'll start getting bogged down making some sort of whining noise and not wanting to move, however when placed upside down it works just fine? I was wondering if I could get some help diagnosing the problem or maybe find another chassis to swap the body onto that would fit nicely. Thanks!
Old 01-30-2023, 03:19 PM
1QwkSport2.5r
1QwkSport2.5r's Avatar
If it uses a rechargeable NiCd battery pack, the battery pack is probably shot. I’d replace the pack (this might require doing some digging to find a suitable replacement that will fit, and likely soldering the connector onto the new pack.)
Old 01-30-2023, 05:29 PM
Totaldoom21
It's not the battery because I've tried brand new ones, I've been told maybe it's something with the motor?
Old 02-02-2023, 11:48 AM
Big Alice
Sounds like, from your description, the pinion gear is loose and slipping on the motor shaft.
