engine help
ok i got my engine half running rite again but now it doestn want to mount right it keeps slipping on the gears and going no where iim am about tired of it not running right and i cant figure out whty it keeps messign up
please help im leavin tomorrow nite for colorado and i wont bring it if i cant fix it
try the paper test: (does this work for nitros?)
put a piece of paper in between your gear mesh and pull it out. if the paper rips, your mesh is too tight. if it comes out easy, too loose. if the gears spin and the paper stays intact then your just fine. you might also want to check the engine and the way its mounted. try moving it around until the thing works.
