Schotty Diode
Old 07-25-2004, 06:56 PM
Default Schotty Diode
I have a quantum super sport esp without reverse and it comes with a scotty diode.
Do I have to solder this directly to the motor or can I solder it into the wires comming
from the esp to make motor changes easier?
Old 07-25-2004, 07:23 PM
Default RE: Schotty Diode
i think it has to be solder onto the motor tabs directly... if you want to test it though just make some little slits in the wires and stick the diode arms in them
Old 07-25-2004, 07:37 PM
Thanks. I will be soldering it to the motor. I don't want to mess anything up if I can avoid it.
Old 07-25-2004, 07:38 PM
ya its best not to mess with these typwe of things
Old 07-25-2004, 11:30 PM
fhm101's Avatar
Back when I raced electric, it was not uncommon to see cars with the shottkey (SP) diode on the motor wires rather than the motor. Putting it on the wires makes it simpler to change motors without having to have a seperate diode for each motor you own.
Old 07-26-2004, 08:10 AM
If you're swapping motors consistantly, a schotky diode is a small investment to make for each motor...
Old 07-26-2004, 12:32 PM
fhm101's Avatar
When you look in a pit box and see 40 to 50 motors, an individual diode per motor can get kinda spendy. I never had more than 4 or 5 motors so I always put a diode and capacitors on all mine, but it can be done either way and work just as well. BTW, it was the folks showing up with the 40 or more motors to race in stock electric that caused me to lose interest in electric.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
